[問題] subMerged風格的問題
phpBB 2 Style Support
leon1235
文章: 19
註冊時間: 2005-11-26 16:31
[問題] subMerged風格的問題
文章 由 leon1235 »
1.還有請問一下網頁左上角的地方 ". / 首頁" 該怎麼拿掉?
2.還有瀏覽器最左上. / XXX首頁 首頁"... 怎嚜拿掉?
風格下載位置:
http://www.phpbb.com/phpBB/catdb.php?mo ... id=1484656
我的論壇:
http://140.127.114.178/phpBB/
請各位大大幫幫忙!!
謝謝......
SCR
文章: 330
註冊時間: 2006-03-11 23:21
來自: 網路的小角落
文章 由 SCR »
我沒實際去下載該風格檔案,請把你的 templates/subMerged/overall_header.tpl 檔案給直接貼出來.
知難非行易,知易反行難~~
leon1235
文章: 19
文章 由 leon1235 »
SCR 寫:我沒實際去下載該風格檔案,請把你的 templates/subMerged/overall_header.tpl 檔案給直接貼出來.
麻煩你了
<!DOCTYPE HTML PUBLIC '-//W3C//DTD HTML 4.01 Transitional//EN'>
<html dir='{S_CONTENT_DIRECTION}'>
<head>
{META}
{NAV_LINKS}
<meta http-equiv='Content-Type' content='text/html; charset={S_CONTENT_ENCODING}'>
<meta name='author' content='redhair'>
<meta name='copyright' content='subMerged style by redhair for phpBB Copyright 2005, All Rights Reserved'>
<link rel="stylesheet" href="templates/subMerged/{T_HEAD_STYLESHEET}" type="text/css">
<!-- BEGIN switch_enable_pm_popup -->
<script language="Javascript" type="text/javascript">
	if ( {PRIVATE_MESSAGE_NEW_FLAG} )
		window.open('{U_PRIVATEMSGS_POPUP}', '_phpbbprivmsg', 'HEIGHT=225,resizable=yes,WIDTH=400');;
</script>
<!-- END switch_enable_pm_popup -->
<script language="JavaScript">
function newImage(arg) {
 if (document.images) {
 rslt = new Image();
 rslt.src = arg;
 return rslt;
function changeImages() {
 if (document.images && (preloadFlag == true)) {
 for (var i=0; i<changeImages.arguments.length; i+=2) {
 document[changeImages.arguments[i]].src = changeImages.arguments[i+1];
var preloadFlag = false;
function preloadImages() {
 send_0_over = newImage("templates/subMerged/images/send_0-over.gif");
 preloadFlag = true;
</script>
<script src='templates/subMerged/fade.js' language='Javascript'></script>
<script src='templates/subMerged/checkbox.js' language='Javascript'></script>
<link rel="shortcut icon" href="templates/subMerged/images/subMerged.ico">
<title>. / {L_INDEX} {PAGE_TITLE}</title>
</head>
<body scroll='auto' onload='preloadImages();replaceChecks()'>
<!-- OVERLIB STUFF !-->
<script type="text/javascript">
  var ol_textfont = "Verdana,Arial,Helvetica";
  var ol_textcolor='#ffffff';
  var ol_width=20;
  var ol_height=12;
  //var ol_fgbackground='templates/subMerged/images/subInfo_overlay.gif';
  var ol_cellpad='1,1,1,1';
  var ol_textsize='10px';
  var ol_border='2';
</script>
<script language="JavaScript" src="templates/subMerged/overlib.js"></script>
<a name='top'></a>
<div class='top_menu'>
<table width='100%' border='0' cellspacing='0' cellpadding='0'>
		<td align='center'>
		<table border='0' cellspacing='0' cellpadding='0'>
				<td align='right' valign='top'><img src='templates/subMerged/images/menu/subTop_left.gif' border='0' width='106' height='23'></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_INDEX}</td></tr></table>');" onmouseout="return nd();" href='{U_INDEX}'><img src='templates/subMerged/images/menu/subMenu_home.gif' border='0' width='19' height='19'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_FAQ}</td></tr></table>');" onmouseout="return nd();" href='{U_FAQ}'><img src='templates/subMerged/images/menu/subMenu_faq.gif' border='0' width='9' height='17'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_SEARCH}</td></tr></table>');" onmouseout="return nd();" href='{U_SEARCH}'><img src='templates/subMerged/images/menu/subMenu_search.gif' border='0' width='17' height='19'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_SEARCH_UNANSWERED}</td></tr></table>');" onmouseout="return nd();" href='{U_SEARCH_UNANSWERED}'><img src='templates/subMerged/images/menu/subMenu_unanswered.gif' border='0' width='21' height='20'></a></td>
				<!-- BEGIN switch_user_logged_in -->
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_SEARCH_NEW}</td></tr></table>');" onmouseout="return nd();" href='{U_SEARCH_NEW}'><img src='templates/subMerged/images/menu/subMenu_postsince.gif' border='0' width='26' height='20'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_SEARCH_SELF}</td></tr></table>');" onmouseout="return nd();" href='{U_SEARCH_SELF}'><img src='templates/subMerged/images/menu/subMenu_userposts.gif' border='0' width='26' height='20'></a></td>
				<!-- END switch_user_logged_in -->
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_MEMBERLIST}</td></tr></table>');" onmouseout="return nd();" href='{U_MEMBERLIST}'><img src='templates/subMerged/images/menu/subMenu_members.gif' border='0' width='25' height='19'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_USERGROUPS}</td></tr></table>');" onmouseout="return nd();" href='{U_GROUP_CP}'><img src='templates/subMerged/images/menu/subMenu_groups.gif' border='0' width='34' height='20'></a></td>
				<!-- BEGIN switch_user_logged_out -->
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_REGISTER}</td></tr></table>');" onmouseout="return nd();" href="{U_REGISTER}"><img src='templates/subMerged/images/menu/subMenu_register.gif' border='0' width='15' height='16'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_LOGIN_LOGOUT}</td></tr></table>');" onmouseout="return nd();" href="{U_LOGIN_LOGOUT}"><img src='templates/subMerged/images/menu/subMenu_loginout.gif' border='0' width='13' height='18'></a></td>
				<td height='22' align='center' class='header_menu' nowrap><a onmouseover="return overlib('<table><tr><td class=nieuws_info nowrap>{L_PROFILE}</td></tr></table>');" onmouseout="return nd();" href='{U_PROFILE}'><img src='templates/subMerged/images/menu/subMenu_profile.gif' border='0' width='17' height='19'></a></td>
				<td align='left' valign='top'><img src='templates/subMerged/images/menu/subTop_right.gif' border='0' width='106' height='23'></td>
		</table>
		</td>
</table>
</div>
<table border='0' cellspacing='0' width='100%' cellpadding='0' class='top'>
		<td width='1%'><a href='{U_INDEX}'><img src='templates/subMerged/images/submerged1.gif' border='0' width='100' height='80'></a></td>
		<td width='98%' valign='middle'><b><a href='{U_INDEX}' class='page_title'>. / {PAGE_TITLE}</a></b></td>
		<td width='1%'><img src='templates/subMerged/images/top_sub.gif' width='180'></td>
</table>
<div align='center'><center>
leon1235
文章: 19
文章 由 leon1235 »
請哪位高手幫幫忙
SCR
文章: 330
來自: 網路的小角落
文章 由 SCR »
關於 瀏覽器最左上". / XXX首頁 首頁" 的部份
找尋
改成
<title>{L_INDEX} {PAGE_TITLE}</title>
以及在管理控制台的一般管理→基本組態→討論區名稱→改成電力品質研究室專屬論壇("首頁"字樣拿掉)
左上角 "./首頁" 部份
找尋
改成
<td width='98%' valign='middle'><b><a href='{U_INDEX}' class='page_title'>{PAGE_TITLE}</a></b></td>
或 (如果你不想要有頁面導覽)
<td width='98%' valign='middle'> </td>
知難非行易,知易反行難~~
leon1235
文章: 19
文章 由 leon1235 »
SCR 寫:關於 瀏覽器最左上". / XXX首頁 首頁" 的部份
找尋
改成
左上角 "./首頁" 部份
找尋
改成
或 (如果你不想要有頁面導覽)
真是幫了大忙,趕緊試試
謝謝你
leon1235
文章: 19
文章 由 leon1235 »
可是我原來就沒有打"首頁"啊,我想把兩個"首頁"拿掉,好像沒辦法
SCR
文章: 330
來自: 網路的小角落
文章 由 SCR »
那把
改成
<title>{SITENAME} {PAGE_TITLE}</title>
試試看!!若再不行,把你的版本資料給補齊~~
知難非行易,知易反行難~~
leon1235
文章: 19
文章 由 leon1235 »
SCR 寫:那把
改成
我明天在試[目前人不再學校主機旁],若有問題我再來發問
leon1235
文章: 19
文章 由 leon1235 »
問題以解決
回到「風格問題討論」
