[新聞]phpBB2 Plus 1.53a Full Package 6/17
phpBB Plus Support
godbless
文章: 647
註冊時間: 2002-05-17 06:02
來自: 台北市南京東路4段
文章 godbless »
Changes from phpBB2 Plus 1.53 Final -> 1.53a
- CrackerTracker v4.1.7 updatet
- Ajax-feature-hack to v1.0.3 updatet with CT integration
- 2nd mistake in profil_add_body.tpl fixed (onnicon)
- memberlist_body.tpl html-comment re-designed
- cache changes in common.php + functions_color_groups.php
- file+folder-writepermissions Checker added
- typos in english/lang_admin_captcha.php fixed (Reliable)
- admin_mass_mail.php -workaround (cYbercOsmOnauT)
- Attachment-Mod v2.4.3 updatet
- header-topiccalendar-cache included
- kb-articlesort @ latest fixed
- security-fixes in kb, hacklist + pafiledb
- added phpBB 2.0.21 Code Changes (with fix)
- custom-profile-fileds "require" fixed
phpBB2 Plus 1.53a is a phpBB 2.0.21 Version with Mods preinstalled.
Installed Mods: Categories Hierarchie Mod, Gender Mod, Last Visit Mod, Card Ban Mod, Topic Calendar Mod, Statistics Mod, Advanced Links Mod, Country Flag Mod, Print Topic Mod, Tell a Friend Mod, Today at/Yesterday at Mod, Message Icon Mod, Online Status Mod, Advanced Quick Reply Mod, CMX News Mod, Scroll BBCode Mod, Fade BBCode Mod, Glow & Shadow BBCode Mod, Stream BBCode Mod, Flash BBCode Mod, Highlight BBCode Mod, PHP Code BBCode Mod, Photo Album Mod, Template fisubsilver Shadow 2.11, Smartors Portal Administration Mod, Junior Admin Mod, Color Groups Mod, Moved Folder Image Mod, Opacity Buttons Mod, FI Navslices Mod, Complete Banner Mod, Announcement Suite Mod and some more...
這個版本已經把phpBB 2.0.21修改的部分都納入了,請直接下載,解壓縮後上傳覆蓋即可使用
http://www.phpbb2.de/dload.php?action=file&file_id=828
強烈建議一定要升級!
新增語系檔:
lang_admin.php
//Added for Folder Permission Check in Admin Panel
$lang['Permission_Check'] = '<u>權限確認:</u><br /><br />權限確認錯誤:';
$lang['File_not_writable_666'] = '<font color="red"><b>無法寫入!</b> [請修改權限為 666]</font>';
$lang['File_not_writable_777'] = '<font color="red"><b>無法寫入!</b> [請修改權限為 777]</font>';
外掛問題區發問格式就在這裡,請務必一定照著格式來~!
你不照著規則來,就算是也搞不清楚你的問題在哪裡!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
PCHANG
文章: 47
註冊時間: 2003-10-10 03:10
文章 PCHANG »
請問是否先安裝這個版本
然後再安裝"語系包"就一樣是中文版
感謝指導^^
PS.抱歉稍早字誤....已修正^^
安裝問題已解決...
我是將>>phpBB2 Plus 1.53 中文化(UTF-8)1.0.2 版
覆蓋於>>phpBB2 Plus 1.53a Full Package 6/17
一路安裝均為"中文版"
感謝辛苦的站長以及各位^^
最後由 PCHANG 於 2006-06-22 04:27 編輯,總共編輯了 2 次。
~~~~~~~~~ 感謝您的指導與建議 ~~~~~~~~~
●主機資訊A:(主機商)
◎作業系統 Linux
◎核心版本 2.4.21-32.ELsmp
◎Apache 版本 1.3.41 (Unix)
◎PHP 版本 4.4.8
◎MySQL 版本 4.1.22-standard-log
◎phpMyAdmin 版本 2.11.4
●上網方式:光纖 (ISP:HINET-10M以上)。
●phpBB 版本:改版中...。
:idea: :?: :!: 非老手上陣~請多協助 :!: :?: :idea:
godbless
文章: 647
來自: 台北市南京東路4段
文章 godbless »
PCHANG 寫: 然後再安裝與戲就一樣是中文
老實說:看不懂你上面這句的意思
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
godbless
文章: 647
來自: 台北市南京東路4段
文章 godbless »
PCHANG 寫:請問是否先安裝這個版本
然後再安裝"語系包"就一樣是中文版
感謝指導^^
PS.抱歉稍早字誤....已修正^^
安裝問題已解決...
一路安裝均為"中文版"
感謝辛苦的站長以及各位^^
是的!不過現在我們有中文語系有更新到了1.0.3版
有些小地方有修正!也完成幾個檔案的語系翻譯!
新手問問題不是罪惡
竹貓星球發問規則:
發問比率最高的句子翻譯:
qqabc
文章: 16
註冊時間: 2005-05-10 01:12
文章 qqabc »
不能下載了該怎辦?
新手是不是應該先去用 PLUS比較好呢?
有人可以給我一點意見嗎?
好想自己弄一個說...可是遇到裝外掛 就不會了!!
我想讓我的論壇有 隱藏文章 . 貨幣 . 徽章系統 外掛就好~
不知道該怎麼作...有人可以幫幫忙嗎? 因為我不會改那個所謂的後續....
很感謝大家...
wu2017
文章: 359
註冊時間: 2002-08-20 15:23
來自: 平凡心動
文章 wu2017 »
qqabc 寫:不能下載了該怎辦?
有人可以給我一點意見嗎?
很感謝大家...
你需要的這些功能,PLUS 1.53 並未包含在內。
jiaruey
文章: 6
註冊時間: 2006-08-27 18:17
文章 jiaruey »
請問
德國官網是否掛了
還有無其他地方可下載
或有已下載過的大大可提供
t54185
文章: 72
註冊時間: 2006-08-24 12:48
Re: [新聞]phpBB2 Plus 1.53a Full Package 6/17
文章 t54185 »
godbless 寫:
強烈建議一定要升級!
新增語系檔:
lang_admin.php
請問 phpBB2 Plus 跟 PHPBB 2.0.21 這是兩套不一樣的嗎
還是說 昇級套件??? 有點不懂兩者關係 @@?
wu2017
文章: 359
來自: 平凡心動
文章 wu2017 »
phpBB Plus (v1.53a) = phpBB (v2.0.21) + 80 多種外掛功能
Plus 內含以下功能:
附件上傳 / 快速回覆 / 12生肖 / 聊天留言板 / 檔案下載 / 相簿藝廊 / 更多的 BBcode 功能 / 推薦網站 ......
jiaruey
文章: 6
文章 jiaruey »
請教有玩plus1.53a 的大大,
入口頁面 右上方 有個登入狀態
但因 日期長度的問題 造成有被分割的情形
使得登入狀態看起來像這樣
您最後訪問於 發表在今天
01:49
現在的時間是 2006-08-
29, 03:53
請問有沒辦法解決?
另有一個小建議, 由於 plus1.53 已經沒有 "contrib資料夾" 了
因此, 中文版 安裝完後還是會要求 把 "contrib資料夾" 殺掉
有點美中不足
bibo8045
文章: 85
註冊時間: 2005-03-06 18:34
文章 bibo8045 »
jiaruey 寫:請問
德國官網是否掛了
還有無其他地方可下載
或有已下載過的大大可提供
剛剛試過好了..前天晚上的確是不行!!
現在可以下載了..快唷!
foolman
註冊時間: 2003-09-08 08:53
文章 foolman »
我目前用的是 phpBB2 Plus 1.52 phpBB 2.0.19,
是否可以直接使用這個版本update 嗎?
若是可以,
是要用 update 目錄中的
update_plus152_to_153.php 還是 update_to_latest.php ?
謝謝~~
lawrencelee
文章: 35
註冊時間: 2005-03-25 16:39
文章 lawrencelee »
我按照指示,下載後解壓縮,上傳到空間裡放phpbb 2.0.22的資料夾
但是卻沒有任何變化?
還是跟原來的論壇一樣
另外關於新增語系的部分,是要把程式碼直接貼到lang_admin.php裡面嗎?
hsientsung
文章: 42
註冊時間: 2006-04-06 01:05
文章 hsientsung »
請問我的版本是 phpBB2 Plus 1.53 based on phpBB 2.0.22 ,不知道您所發佈的,我需不需要進行更新?
善用搜尋是很棒的選擇,但是~~
爬文好辛苦啊~ (╯▔︹▔)╯~╘═╛
wu2017
文章: 359
來自: 平凡心動
文章 wu2017 »
foolman 寫:我目前用的是 phpBB2 Plus 1.52 phpBB 2.0.19,
若是可以,
是要用 update 目錄中的
謝謝~~
用 update 目錄中的 index.php
資料來源: phpBB2_Plus_153a_readme_english.html
回到「phpBB 2 plus 綜合討論」
