[外掛]Large Images MOD
atthis
文章: 216
註冊時間: 2003-07-29 19:16
文章 由 atthis »
原始出處:http://www.phpbb.com/phpBB/viewtopic.php?t=131667
Demo:http://www.op.osw.pl/forum/viewtopic.php?t=14
可自訂圖片最大寬度,超過寬度的圖片會在圖片下自動產生捲軸以維持版面\r
原安裝[教學]貼圖效果的會失去自動裁減的功能\r
檔頭:
## MOD Title:          Large Images MOD
## MOD Author:         Sian < sebastian.weglarczyk@interia.pl > (Sebastian W璕larczyk)
## MOD Description:    This MOD will allow the board administrators
##                     to set maximum width of an posted images.
##                     If width of an image exceeds entered value,
##                     a horizontal scrollbar will appear under image.
##                     This will maintain forum layout.
##                     Entering zero or leaving empty disables this function.
## MOD Version:        1.0.0
## Compatibility:      2.0.4 - 2.0.6 (prior release not tested but expected to work fine)
## Installation Level: Easy
## Installation Time:  ~5 Minutes
## Files To Edit:      5
##      admin/admin_board.php
##      includes/bbcode.php
##      language/lang_english/lang_admin.php
##      templates/subSilver/viewtopic_body.tpl
##      templates/subSilver/admin/board_config_body.tpl
## Included Files: n/a
## Author Notes:
##	To set maximum image width:
##	Go to administration panel -> General Admin -> Configuration -> User and Forum Basic Settings
##	This mod should work with any template, although there will be differences in the .tpl
##	files with some templates. You should be able to work around the differences.
##	If you have other templates or languages installed you should modify respective files.
## MOD History:
##   2003-08-27 - Version 1.0.0
##      - Initial final release
中文化:
只有兩行
#-----[ 開啟 ]------------------------------------------------
#-----[ 尋找 ]------------------------------------------------
$lang['Max_sig_length_explain']
#-----[ 之後加入 ]-----------------------------------------
// Start add - LargeImages MOD
$lang['Max_image_width'] = '最大圖片寬度';
$lang['Max_image_width_explain'] = '如果圖片寬度大於這個值, 在圖片下會自動產生捲軸以維持版面, 設定為0或留白可關閉此功能.';
// End add - LargeImages MOD
功能設定在 "系統管理控制台"->"一般管理"->"基本組態"->"最大圖片寬度"
我設定580差不多可以塞滿版面
回到「非官方認證外掛」
