[問題] session force在phpbb 2.0.21版的問題 (已解決)
dean20
文章: 61
註冊時間: 2005-04-08 21:38
來自: 地球
文章 由 dean20 »
各位大大好...
小弟我在phpbb2.0.21使用session force...
此功能是在討論區會顯示訪客..
但安裝完後.. 我以訪客身份流覽...
卻出現正在瀏覽此區的會員: 沒有
請問session force在phpbb2.0.21有用嗎??
ps.我有按照官方網站的改法修正...
以下為為的sessions.php的內碼
<?php
 *                                sessions.php
 *   $Id: sessions.php,v 1.58.2.25 2006/05/18 19:23:07 grahamje Exp $
// Adds/updates a new session to the database for the given userid.
// Returns the new session ID on success.
function session_begin($user_id, $user_ip, $page_id, $auto_create = 0, $enable_autologin = 0, $admin = 0)
	global $db, $board_config;
	global $HTTP_COOKIE_VARS, $HTTP_GET_VARS, $SID;
	$cookiename = $board_config['cookie_name'];
	$cookiepath = $board_config['cookie_path'];
	$cookiedomain = $board_config['cookie_domain'];
	$cookiesecure = $board_config['cookie_secure'];
	if ( isset($HTTP_COOKIE_VARS[$cookiename . '_sid']) || isset($HTTP_COOKIE_VARS[$cookiename . '_data']) )
		$session_id = isset($HTTP_COOKIE_VARS[$cookiename . '_sid']) ? $HTTP_COOKIE_VARS[$cookiename . '_sid'] : '';
		$sessiondata = isset($HTTP_COOKIE_VARS[$cookiename . '_data']) ? unserialize(stripslashes($HTTP_COOKIE_VARS[$cookiename . '_data'])) : array();
		$sessionmethod = SESSION_METHOD_COOKIE;
		$sessiondata = array();
		$session_id = ( isset($HTTP_GET_VARS['sid']) ) ? $HTTP_GET_VARS['sid'] : '';
		$sessionmethod = SESSION_METHOD_GET;
	if (!preg_match('/^[A-Za-z0-9]*$/', $session_id))
		$session_id = '';
	$page_id = (int) $page_id;
	$last_visit = 0;
	$current_time = time();
	// Are auto-logins allowed?
	// If allow_autologin is not set or is true then they are
	// (same behaviour as old 2.0.x session code)
	if (isset($board_config['allow_autologin']) && !$board_config['allow_autologin'])
		$enable_autologin = $sessiondata['autologinid'] = false;
	// First off attempt to join with the autologin value if we have one
	// If not, just use the user_id value
	$userdata = array();
	if ($user_id != ANONYMOUS)
		if (isset($sessiondata['autologinid']) && (string) $sessiondata['autologinid'] != '' && $user_id)
			$sql = 'SELECT u.*
				FROM ' . USERS_TABLE . ' u, ' . SESSIONS_KEYS_TABLE . ' k
				WHERE u.user_id = ' . (int) $user_id . "
					AND u.user_active = 1
					AND k.user_id = u.user_id
					AND k.key_id = '" . md5($sessiondata['autologinid']) . "'";
				message_die(CRITICAL_ERROR, 'Error doing DB query userdata row fetch', '', __LINE__, __FILE__, $sql);
			$userdata = $db->sql_fetchrow($result);
			$db->sql_freeresult($result);
			$enable_autologin = $login = 1;
		else if (!$auto_create)
			$sessiondata['autologinid'] = '';
			$sessiondata['userid'] = $user_id;
			$sql = 'SELECT *
				WHERE user_id = ' . (int) $user_id . '
					AND user_active = 1';
			$login = 1;
	// At this point either $userdata should be populated or
	// one of the below is true
	// * Key didn't match one in the DB
	// * User does not exist
	// * User is inactive
	if (!sizeof($userdata) || !is_array($userdata) || !$userdata)
		$sessiondata['userid'] = $user_id = ANONYMOUS;
		$enable_autologin = $login = 0;
		$sql = 'SELECT *
			WHERE user_id = ' . (int) $user_id;
	// Initial ban check against user id, IP and email address
	preg_match('/(..)(..)(..)(..)/', $user_ip, $user_ip_parts);
	$sql = "SELECT ban_ip, ban_userid, ban_email
		FROM " . BANLIST_TABLE . "
		WHERE ban_ip IN ('" . $user_ip_parts[1] . $user_ip_parts[2] . $user_ip_parts[3] . $user_ip_parts[4] . "', '" . $user_ip_parts[1] . $user_ip_parts[2] . $user_ip_parts[3] . "ff', '" . $user_ip_parts[1] . $user_ip_parts[2] . "ffff', '" . $user_ip_parts[1] . "ffffff')
			OR ban_userid = $user_id";
	if ( $user_id != ANONYMOUS )
		$sql .= " OR ban_email LIKE '" . str_replace("\'", "''", $userdata['user_email']) . "'
			OR ban_email LIKE '" . substr(str_replace("\'", "''", $userdata['user_email']), strpos(str_replace("\'", "''", $userdata['user_email']), "@")) . "'";
		message_die(CRITICAL_ERROR, 'Could not obtain ban information', '', __LINE__, __FILE__, $sql);
	if ( $ban_info = $db->sql_fetchrow($result) )
		if ( $ban_info['ban_ip'] || $ban_info['ban_userid'] || $ban_info['ban_email'] )
			message_die(CRITICAL_MESSAGE, 'You_been_banned');
	// Create or update the session
	$sql = "UPDATE " . SESSIONS_TABLE . "
		SET session_user_id = $user_id, session_start = $current_time, session_time = $current_time, session_page = $page_id, session_logged_in = $login, session_admin = $admin
		WHERE session_id = '" . $session_id . "'
			AND session_ip = '$user_ip'";
	if ( !$db->sql_query($sql) || !$db->sql_affectedrows() )
		$session_id = md5(dss_rand());
		$sql = "INSERT INTO " . SESSIONS_TABLE . "
			(session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin)
			VALUES ('$session_id', $user_id, $current_time, $current_time, '$user_ip', $page_id, $login, $admin)";
		if ( !$db->sql_query($sql) )
			message_die(CRITICAL_ERROR, 'Error creating new session', '', __LINE__, __FILE__, $sql);
		$last_visit = ( $userdata['user_session_time'] > 0 ) ? $userdata['user_session_time'] : $current_time;
		if (!$admin)
				SET user_session_time = $current_time, user_session_page = $page_id, user_lastvisit = $last_visit
				WHERE user_id = $user_id";
				message_die(CRITICAL_ERROR, 'Error updating last visit time', '', __LINE__, __FILE__, $sql);
		$userdata['user_lastvisit'] = $last_visit;
		// Regenerate the auto-login key
		if ($enable_autologin)
			$auto_login_key = dss_rand() . dss_rand();
			if (isset($sessiondata['autologinid']) && (string) $sessiondata['autologinid'] != '')
				$sql = 'UPDATE ' . SESSIONS_KEYS_TABLE . "
					SET last_ip = '$user_ip', key_id = '" . md5($auto_login_key) . "', last_login = $current_time
					WHERE key_id = '" . md5($sessiondata['autologinid']) . "'";
				$sql = 'INSERT INTO ' . SESSIONS_KEYS_TABLE . "(key_id, user_id, last_ip, last_login)
					VALUES ('" . md5($auto_login_key) . "', $user_id, '$user_ip', $current_time)";
				message_die(CRITICAL_ERROR, 'Error updating session key', '', __LINE__, __FILE__, $sql);
			$sessiondata['autologinid'] = $auto_login_key;
			unset($auto_login_key);
//		$sessiondata['autologinid'] = (!$admin) ? (( $enable_autologin && $sessionmethod == SESSION_METHOD_COOKIE ) ? $auto_login_key : '') : $sessiondata['autologinid'];
	$userdata['session_id'] = $session_id;
	$userdata['session_ip'] = $user_ip;
	$userdata['session_user_id'] = $user_id;
	$userdata['session_logged_in'] = $login;
	$userdata['session_page'] = $page_id;
	$userdata['session_start'] = $current_time;
	$userdata['session_time'] = $current_time;
	$userdata['session_admin'] = $admin;
	$userdata['session_key'] = $sessiondata['autologinid'];
	setcookie($cookiename . '_data', serialize($sessiondata), $current_time + 31536000, $cookiepath, $cookiedomain, $cookiesecure);
	setcookie($cookiename . '_sid', $session_id, 0, $cookiepath, $cookiedomain, $cookiesecure);
	$SID = 'sid=' . $session_id;
	return $userdata;
// Checks for a given user session, tidies session table and updates user
// sessions at each page refresh
function session_pagestart($user_ip, $thispage_id, $session_force = 0)
	global $db, $lang, $board_config;
	unset($userdata);
		$sessiondata = isset( $HTTP_COOKIE_VARS[$cookiename . '_data'] ) ? unserialize(stripslashes($HTTP_COOKIE_VARS[$cookiename . '_data'])) : array();
		$session_id = isset( $HTTP_COOKIE_VARS[$cookiename . '_sid'] ) ? $HTTP_COOKIE_VARS[$cookiename . '_sid'] : '';
		$session_id = '';
	$thispage_id = (int) $thispage_id;
	// Does a session exist?
	if ( !empty($session_id) )
		// session_id exists so go ahead and attempt to grab all
		// data in preparation
		$sql = "SELECT u.*, s.*
			FROM " . SESSIONS_TABLE . " s, " . USERS_TABLE . " u
			WHERE s.session_id = '$session_id'
				AND u.user_id = s.session_user_id";
		// Did the session exist in the DB?
		if ( isset($userdata['user_id']) )
			// Do not check IP assuming equivalence, if IPv4 we'll check only first 24
			// bits ... I've been told (by vHiker) this should alleviate problems with
			// load balanced et al proxies while retaining some reliance on IP security.
			$ip_check_s = substr($userdata['session_ip'], 0, 6);
			$ip_check_u = substr($user_ip, 0, 6);
			if ($ip_check_s == $ip_check_u)
				$SID = ($sessionmethod == SESSION_METHOD_GET || defined('IN_ADMIN')) ? 'sid=' . $session_id : '';
				// Only update session DB a minute or so after last update
				if (($current_time - $userdata['session_time'] > 60) or $session_force)
					// A little trick to reset session_admin on session re-usage
					$update_admin = (!defined('IN_ADMIN') && $current_time - $userdata['session_time'] > ($board_config['session_length']+60)) ? ', session_admin = 0' : '';
						SET session_time = $current_time, session_page = $thispage_id$update_admin
						WHERE session_id = '" . $userdata['session_id'] . "'";
						message_die(CRITICAL_ERROR, 'Error updating sessions table', '', __LINE__, __FILE__, $sql);
					if ( $userdata['user_id'] != ANONYMOUS )
							SET user_session_time = $current_time, user_session_page = $thispage_id
							WHERE user_id = " . $userdata['user_id'];
					session_clean($userdata['session_id']);
				// Add the session_key to the userdata array if it is set
				if ( isset($sessiondata['autologinid']) && $sessiondata['autologinid'] != '' )
				return $userdata;
	// If we reach here then no (valid) session exists. So we'll create a new one,
	// using the cookie user_id if available to pull basic user prefs.
	$user_id = ( isset($sessiondata['userid']) ) ? intval($sessiondata['userid']) : ANONYMOUS;
	if ( !($userdata = session_begin($user_id, $user_ip, $thispage_id, TRUE)) )
		message_die(CRITICAL_ERROR, 'Error creating user session', '', __LINE__, __FILE__, $sql);
	return $userdata;
* Terminates the specified session
* It will delete the entry in the sessions table for this session,
* remove the corresponding auto-login key and reset the cookies
function session_end($session_id, $user_id)
	global $db, $lang, $board_config, $userdata;
		return;
	// Delete existing session
	$sql = 'DELETE FROM ' . SESSIONS_TABLE . "
		WHERE session_id = '$session_id'
			AND session_user_id = $user_id";
		message_die(CRITICAL_ERROR, 'Error removing user session', '', __LINE__, __FILE__, $sql);
	// Remove this auto-login entry (if applicable)
	if ( isset($userdata['session_key']) && $userdata['session_key'] != '' )
		$autologin_key = md5($userdata['session_key']);
		$sql = 'DELETE FROM ' . SESSIONS_KEYS_TABLE . '
			WHERE user_id = ' . (int) $user_id . "
				AND key_id = '$autologin_key'";
			message_die(CRITICAL_ERROR, 'Error removing auto-login key', '', __LINE__, __FILE__, $sql);
	// We expect that message_die will be called after this function,
	// but just in case it isn't, reset $userdata to the details for a guest
	$sql = 'SELECT *
		WHERE user_id = ' . ANONYMOUS;
		message_die(CRITICAL_ERROR, 'Error obtaining user details', '', __LINE__, __FILE__, $sql);
	if ( !($userdata = $db->sql_fetchrow($result)) )
	setcookie($cookiename . '_data', '', $current_time - 31536000, $cookiepath, $cookiedomain, $cookiesecure);
	setcookie($cookiename . '_sid', '', $current_time - 31536000, $cookiepath, $cookiedomain, $cookiesecure);
	return true;
* Removes expired sessions and auto-login keys from the database
function session_clean($session_id)
	global $board_config, $db;
	// Delete expired sessions
	$sql = 'DELETE FROM ' . SESSIONS_TABLE . '
		WHERE session_time < ' . (time() - (int) $board_config['session_length']) . "
			AND session_id <> '$session_id'";
		message_die(CRITICAL_ERROR, 'Error clearing sessions table', '', __LINE__, __FILE__, $sql);
	// Delete expired auto-login keys
	// If max_autologin_time is not set then keys will never be deleted
	if (!empty($board_config['max_autologin_time']) && $board_config['max_autologin_time'] > 0)
			WHERE last_login < ' . (time() - (86400 * (int) $board_config['max_autologin_time']));
		$db->sql_query($sql);
	return true;
* Reset all login keys for the specified user
* Called on password changes
function session_reset_keys($user_id, $user_ip)
	global $db, $userdata, $board_config;
	$key_sql = ($user_id == $userdata['user_id'] && !empty($userdata['session_key'])) ? "AND key_id != '" . md5($userdata['session_key']) . "'" : '';
			$key_sql";
		message_die(CRITICAL_ERROR, 'Error removing auto-login keys', '', __LINE__, __FILE__, $sql);
	$where_sql = 'session_user_id = ' . (int) $user_id;
	$where_sql .= ($user_id == $userdata['user_id']) ? " AND session_id <> '" . $userdata['session_id'] . "'" : '';
		WHERE $where_sql";
		message_die(CRITICAL_ERROR, 'Error removing user session(s)', '', __LINE__, __FILE__, $sql);
	if ( !empty($key_sql) )
			WHERE key_id = '" . md5($userdata['session_key']) . "'";
		// And now rebuild the cookie
		$userdata['session_key'] = $auto_login_key;
		unset($sessiondata);
// Append $SID to a url. Borrowed from phplib and modified. This is an
// extra routine utilised by the session code above and acts as a wrapper
// around every single URL and form action. If you replace the session
// code you must include this routine, even if it's empty.
function append_sid($url, $non_html_amp = false)
	global $SID;
	if ( !empty($SID) && !preg_match('#sid=#', $url) )
		$url .= ( ( strpos($url, '?') !== false ) ?  ( ( $non_html_amp ) ? '&' : '&' ) : '?' ) . $SID;
	return $url;
最後由 dean20 於 2006-06-23 14:00 編輯,總共編輯了 2 次。
架設主機作業系統:Windows Server 2003
上網方式:LOCAL NET
安裝的程式:IIS6.0 + php5.1.4 + MySQL 5.0.22 + phpMyAdmin 2.8.1
版本:PHPBB 2.0.21
*tytsim*
文章: 411
註冊時間: 2005-03-24 11:54
來自: 香港
文章 由 *tytsim* »
訪客不會顯示
 網絡鎮
    關於網絡的
http://tytsim.net.ru  一個網絡鎮
拭銀布
文章: 66
註冊時間: 2003-11-18 19:44
來自: yakuza
Re: [問題] session force在phpbb 2.0.21版的問題
文章 由 拭銀布 »
dean20 寫:此功能是在討論區會顯示訪客..
它不是修正"正在瀏覽此區的會員: 沒有"嗎?
既然是訪客,那又怎麼會顯示呢?
但,如果要顯示訪客,需要加掛 User Icon on Who Is Online 可達到效果!^^
(效果可連到敝小站觀看)
yakuza
dean20
文章: 61
來自: 地球
Re: [問題] session force在phpbb 2.0.21版的問題 (已解決)
文章 由 dean20 »
拭銀布 寫:
既然是訪客,那又怎麼會顯示呢?
(效果可連到敝小站觀看)
看來我把sessions force的功能搞錯了...
是要用大大妳說的這個外掛才對...
謝謝您囉..
上網方式:LOCAL NET
版本:PHPBB 2.0.21
