使用版本:2.0.19
如果我想不要讓所有人都使用簽名檔,而只限特定群組使用。
我參考blog mod改成了這樣:
# Replace "phpbb_" with the prefix of your forums, or use the included db_update.php to run the SQL
ALTER TABLE phpbb_groups ADD group_allow_signature TINYINT(1) UNSIGNED NOT NULL DEFAULT '0';
# REQUIRED - Adds the option to allow/disallow a group to be able to create a blog
admin/admin_groups.php
$group_info = array (
'group_name' => '',
'group_description' => '',
'group_moderator' => '',
'group_allow_signature' => 0,
'U_SEARCH_USER' => append_sid("../search.$phpEx?mode=searchuser"),
'L_WEBLOG_GROUP' => $lang['Group_allow_signature'],
'L_NO' => $lang['No'],
'S_GROUP_ALLOW_SIGN_YES' => ( $group_info['group_allow_signature'] ) ? ' checked="checked"' : '',
'S_GROUP_ALLOW_SIGN_NO' => ( !$group_info['group_allow_signature'] ) ? ' checked="checked"' : '',
$group_moderator = isset($HTTP_POST_VARS['username']) ? $HTTP_POST_VARS['username'] : '';
$group_allow_signature = ( isset($HTTP_POST_VARS['group_allow_signature']) ) ? intval($HTTP_POST_VARS['group_allow_signature']) : 0;
$sql = "UPDATE " . GROUPS_TABLE . "
SET group_type = $group_type, group_name = '" . str_replace("\'", "''", $group_name) . "', group_description = '" . str_replace("\'", "''", $group_description) . "', group_moderator = $group_moderator
, group_allow_signature = $group_allow_signature
$sql = "INSERT INTO " . GROUPS_TABLE . " (group_type, group_name, group_description, group_moderator, group_single_user)
, group_single_user
VALUES ($group_type, '" . str_replace("\'", "''", $group_name) . "', '" . str_replace("\'", "''", $group_description) . "', $group_moderator, '0')";
, $group_allow_signature
// That's all Folks!
$lang['Group_allow_signature'] = '允許群組會員使用簽名檔';
# REQUIRED - Adds the ability to allow/disallow groups the ability to have blogs
templates/subSilver/admin/group_edit_body.tpl
<td class="row1" width="38%"><span class="gen">{L_GROUP_STATUS}:</span></td>
<td class="row2" width="62%">
<input type="radio" name="group_type" value="{S_GROUP_OPEN_TYPE}" {S_GROUP_OPEN_CHECKED} /> {L_GROUP_OPEN} <input type="radio" name="group_type" value="{S_GROUP_CLOSED_TYPE}" {S_GROUP_CLOSED_CHECKED} /> {L_GROUP_CLOSED} <input type="radio" name="group_type" value="{S_GROUP_HIDDEN_TYPE}" {S_GROUP_HIDDEN_CHECKED} /> {L_GROUP_HIDDEN}</td>
<td class="row1" width="38%"><span class="gen">{L_SIGN_GROUP}:</span></td>
<input type="radio" name="group_allow_signature" value="1" {S_GROUP_ALLOW_SIGN_YES} /> {L_YES} <input type="radio" name="group_allow_signature" value="0" {S_GROUP_ALLOW_SIGN_NO} /> {L_NO}</td>
