[求助]請問phpBB & 4images整合後資料庫的問題
牙之塔
文章: 28
註冊時間: 2003-02-22 03:58
來自: 台中
文章 牙之塔 » 2003-08-25 12:52
問題外掛:4images(這…這該算是外掛嗎…= =|||)
參考連結:http://phpbb-tw.net/phpbb/viewtopic.php ... es&start=0
使用版本:phpBB 2.0.3 、 4images 1.7.0
網站位置:已刪除\r
請問各位大大,小弟在安裝了4images並按phpBB論壇架設寶典的說明下與小弟的論壇做了整合,起初一切正常,小弟在其強大的功能下使用的非常快樂,怎料,在小弟回到論壇將帳號登出想再登入時(後續也曾因要檢示會員資料而出現),論壇處竟出現下列訊息:
Parse error: parse error, unexpected T_STRING in c:\appserv\www\phpbb2\language\lang_english\lang_main.php on line 898
phpBB :
Error doing DB query userdata row fetch
SQL Error : 1016 Can't open file: 'phpbb_users.MYD'. (errno: 145)
SELECT u.*, s.* FROM phpbb_sessions s, phpbb_users u WHERE s.session_id = '6708dd8c87f2daedc8cb55f72d5e6c05' AND u.user_id = s.session_user_id AND session_time > 1061748136
Line : 239
File : c:\appserv\www\phpbb2\includes\sessions.php
而4image處則是:
DB Error: Bad SQL Query: SELECT u.*, l.* FROM phpBB_users u, 4images_lightboxes l WHERE u.user_id = 3 AND l.user_id = u.user_id
DB Error: Bad SQL Query: SELECT * FROM phpBB_users WHERE user_id = 3
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\4images\includes\db_mysql.php:188) in c:\appserv\www\4images\includes\sessions.php on line 325
Warning: Cannot add header information - headers already sent by (output started at c:\appserv\www\4images\includes\db_mysql.php:188) in c:\appserv\www\4images\includes\sessions.php on line 326
DB Error: Bad SQL Query: SELECT u.user_id, u.user_level, u.username, u.user_allow_viewonline, s.session_user_id, s.session_time, s.session_ip FROM phpBB_users u, phpBB_sessions s WHERE u.user_id = s.session_user_id AND (s.session_time >= 1061784703 OR u.user_session_time >= 1061784703) ORDER BY u.user_id ASC, s.session_ip ASC
DB Error: Bad SQL Query: SELECT DISTINCT i.image_id, i.cat_id, i.user_id, i.image_name, i.image_description, i.image_keywords, i.image_date, i.image_active, i.image_media_file, i.image_thumb_file, i.image_download_url, i.image_allow_comments, i.image_comments, i.image_downloads, i.image_votes, i.image_rating, i.image_hits, c.cat_name, u.username FROM 4images_images i, 4images_categories c LEFT JOIN phpBB_users u ON (u.user_id = i.user_id) WHERE i.image_active = 1 AND i.cat_id NOT IN (0, 3, 14, 31, 24, 15, 22, 16, 10, 11, 17, 12, 18, 13, 19, 20, 21, 23, 25, 26, 27, 28, 29, 30, 32, 33) AND c.cat_id = i.cat_id ORDER BY RAND()
DB Error: Bad SQL Query: SELECT i.image_id, i.cat_id, i.user_id, i.image_name, i.image_description, i.image_keywords, i.image_date, i.image_active, i.image_media_file, i.image_thumb_file, i.image_download_url, i.image_allow_comments, i.image_comments, i.image_downloads, i.image_votes, i.image_rating, i.image_hits, c.cat_name, u.username FROM 4images_images i, 4images_categories c LEFT JOIN phpBB_users u ON (u.user_id = i.user_id) WHERE i.image_active = 1 AND c.cat_id = i.cat_id AND i.cat_id IN (0) ORDER BY i.image_date DESC LIMIT 3
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in c:\appserv\www\4images\includes\db_mysql.php on line 116
這個問題讓小弟一時間不該如何著手,小弟利用phpmyadmin進入想觀看資料庫,發現在使用者欄位出現\r
[color=black]phpbb_users    瀏覽  選擇[/color]  [color=blue]新增  屬性  刪除[/color] [color=black] 清空  使用中[/color]
而這個欄位僅剩新增、屬性、刪除功能其它均無法使用!!小弟不知該如何解決,在竹貓裡搜尋雖有找到類似文章但仍無法解決,因此發文求助,請站內高手、大大們能給予小弟指導及解答,謝謝!!
補充:
這個問題小弟初步的應對方式是利用phpmyadmin將備份的資料還原,雖然這麼做問題就消失了,但是該症狀無法完全根治!!嚴重時會一天出現個好幾次…\r
小弟的系統是:
Win2000、Apche1.3.26、PHP4.2.3
最後由 牙之塔 於 2003-08-26 07:47 編輯,總共編輯了 1 次。
牙之塔
文章: 28
來自: 台中
文章 牙之塔 » 2003-08-26 07:46
昨晚又發作一次…終於不治身亡了…Q____Q
不只有phpBB_users的欄位,還有4images_images及phpBB_sessions都出現使用中的狀態…\r
小弟還是重灌過好了~~~
